To change the width of a field, drag the divider line between the field names.
If for some reason you want to adjust the width of the field numerically, you can do so with the Field Blueprint Dialog.
In this dialog, the width is specified in characters, not an absolute dimension like points or inches. If you specify a width of 12, there will be approximately enough space to display 12 characters (some characters are wider than others, so this is not exact). The absolute width depends on the font size being used.
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
