visiblefieldnumbers(
The visiblefieldnumbers( function returns a data array of visible fields (by number) in the data sheet.
This function returns a data array (see Data Arrays) of visible fields in the curent data sheet window (it must not be used unless a data sheet window is frontmost). Each array element contains the field number corresponding to a column in the data sheet.
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefields( -- returns a list of visible fields in the data sheet.
