To delete a field from the database, select a cell in the field and click on the Delete tool.
This not only deletes the field, it also deletes any data in the field.
You can also choose Delete Field from the Fields menu, or right click on the field name and choose Delete Field from the pop-up menu, as shown here.
You will not be asked for confirmation of your wish to delete the field, it will just be deleted. But, like any other operation, you can use Undo afterwards if you decide that you didn’t really want to delete the field.
