lastlookupdatabase(
The lastlookupdatabase( function returns the name of the database referenced in the most recent lookup.
This function is designed to be used immediately after a lookup( function. It returns the name of the database that was referenced in that function. But wait, you say – if I just used the lookup( function, won’t I know what database it searched? Well, check out the code for the speedcopy statement to see a case where that isn’t true.
- related( -- searches a database for a record in a related database that matches the current record in the current database based a relational specification (based on one or more key fields or formulas in each database), then uses a formula to return other information from the same record. This is similar to the lookup( function, but instead of using an individual field for the key, a relation is used (see Relational Database Management).
- relatedarray( -- builds an Text Array by scanning a database and creating an array element for every record that matches a relational specification (based on one or more key fields or formulas). This is similar to the arraybuild( function, but instead of using an individual field for the key, a relation is used (see Relational Database Management).
- relatedrecordid( -- returns the record id of a record in a related database that matches the current record in the current database based on a relational specification.
- Relational Workshop -- tool that assists in composing relational lookup(, superlookup(, lookupall( and arraybuild( functions.
