visiblefields(
The visiblefields( function returns a list of visible fields in the data sheet.
This function returns a list of visible fields in the curent data sheet window (it must not be used unless a data sheet window is frontmost). The list is returned as a carriage return delimited list of field names.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
