info("rawrecordid")
The info(“rawrecordid”) function returns a number that represents the location of the current record within the database.
This function returns a number that represents the location of the current record within the database. This value must be used immediately, any change to the data may change this number and render the number invalid. It is normally used only by ProVUE Development.
