dbcheckopen(
DATABASE
The dbcheckopen( function returns true if the specified database is currently open, false if it is not.
database – name of database.
This function returns true if the specified database is currently open, false if it is not.
dbcheckopen("Mailing List") ☞ -1 (true)
arraycontains(info("files"),thedb,cr())
