getstructurevalue(
STRUCTURE
INDEX
The getstructurevalue( function extracts a value from a structure of nested Data Dictionaries and/or Data Arrays.
structure – a structured collection of data. This must be a data dictionary or data array, which may contain nested dictionaries or arrays.
index – is the desired index into the collection. For data dictionaries the index must be text, for data arrays it must be an integer. This parameter can be repeated to access multiple levels of the structure.
This function extracts a value from a structure of nested Data Dictionaries and/or Data Arrays. You can use this function in lieu of multiple nested getdictionaryvalue( and array( functions.
For example, supposed you have a variable named people that contains a data array of different people. Each element of this array contains a dictionary with different attributes for each person (name, address, etc.). One of these attributes is a data array of each person’s children. With this formula, you could find the name of the second child of the 4th person.
array(getdictionaryvalue(array(people,4),"Children"),2)
That’s a rather contorted formula. We can make it much simpler by using the getstructurevalue( function instead.
getstructurevalue(people,4,"Children",2)
In this example the structured data in people has three levels. There is an index parameter for each level of the structure. If the level is an array, the corresponding index parameter must be an integer. If the level is a dictionary, the corresponding index parameter must be text (the name of the desired element).
The getstructurevalue( function is ideal for working with JSON data that has been converted into a Panorama variable with the jsonimport( function. The code below will construct a people variable along the lines discussed above.
let people = jsonimport(|||
{"Name" : "Jack", "Color" : "Blue", "Size" : 38, "Children" : ["Mary", "Ellen", "Mark"]},
{"Name" : "Mary", "Color" : "Red", "Size" : 29, "Children" : ["Wayne"]},
{"Name" : "Bob", "Color" : "Orange", "Size" : 31, "Children" : ["Bill", "Tom"]}
{"Name" : "Eric", "Color" : "Yellow", "Size" : 40, "Children" : ["Jeff", "Ryan"]},
{"Name" : "Rita", "Color" : "Blue", "Size" : 24, "Children" : ["Matthew"]},
The getstructurevalue( function can be used to extract various components of this structured data.
getstructurevalue(people,4,"Children",2) ☞ Ryan
getstructurevalue(people,2,"Name") ☞ Mary
getstructurevalue(people,3,"Size") ☞ 31
You don’t have to include an index for every level of the structure. If you omit one or more levels, the function will return a structure, in this case an array.
arraysize(getstructurevalue(people,3,"Children")) ☞ 2
exportdataarray(getstructurevalue(people,3,"Children"),", ") ☞ Bill, Tom
If you specify an element that doesn’t exist, the getstructurevalue( function will return an error. Use the catcherror( function if you want to ignore the error.
If you’re not sure what an element contains, you can use the binarydatatype( function to find out. For example, if we didn’t already know, we could use this to find out that the Children item contains an array.
binarydatatype(getstructurevalue(people,3,"Children")) ☞ Array
- changedictionaryvalues( -- changes one or more values in a dictionary (see Data Dictionaries).
- classicdictionaryvalue( -- returns the value of an item in the dictionary, given its key (see Data Dictionaries). Unlike getdictionaryvalue(, this function does not treat keys as case sensitive.
- copypartialdictionary( -- partially copies a dictionary (see Data Dictionaries).
- deletedictionaryvalue( -- deletes one or more key/value pairs from a dictionary (see Data Dictionaries).
- dictionaryassignmentscode( -- returns code that can be used to take the values in a dictionary (see Data Dictionaries) and assign them to fields or variables based on the dictionary keys.
- dictionaryfromarray( -- builds a new dictionary and initializes it from a two dimensional text array (see Data Dictionaries and Text Arrays).
- dictionaryfromvariables( -- builds a new dictionary and initializes it from a list of variables (carriage return delimited).
- dictionaryvalueexists( -- returns true or false depending on whether or not a key/value pair exists in a dictionary (see Data Dictionaries).
- dumpdictionary( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries).
- dumpdictionaryquoted( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries). The text values are quoted.
- dumpdictionarysource( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries). The keys and values are quoted so that they could be used to re-assemble the dictionary with the initializedictionary( function.
- getdictionarykey( -- returns the key of an item in the dictionary, given its value). This is essentially the opposite of the getdictionaryvalue( function (see Data Dictionaries).
- getdictionaryvalue( -- returns the value of an item in the dictionary, given its key (see Data Dictionaries).
- getglobaldictionary( -- converts a global dictionary into a regular dictionary.
- Global Dictionaries -- alertnate high performance method to store multiple data items, much faster than regular data dictionaries.
- globaldictionarykeys( -- returns a cr()-separated array containing the keys in a global dictionary, or the names of all global dictionaries.
- globaldictionaryvalue( -- returns the value of an item in a global dictionary, given its key (see Global Dictionaries).
- initializedictionary -- builds a new dictionary and initializes it with one or more key/value entries (see Data Dictionaries).
- initializedictionary( -- builds a new dictionary and initializes it with zero or more key/value entries (see Data Dictionaries).
- initializedictionaryvalue( -- builds a new dictionary and initializes it with one or more entries (see Data Dictionaries). This function is deprecated, we recommend using the initializedictionary( function instead.
- listdictionarykeys( -- returns a list of the keys in a dictionary collection.
- mergedictionaries( -- merges the contents of two or more dictionaries (see Data Dictionaries).
- renamedictionarykey( -- changes the key (name) of one or more values in a dictionary (see Data Dictionaries).
- timerinfo( -- returns a dictionary that contains all of the properties of a timer.
