appenddataarrays(
ARRAY
ANOTHERARRAY
The appenddataarrays( function appends two or more data arrays to each other (see Data Arrays).
array – the initial array to be modified.
anotherarray – additional array to be appended to the first array (this parameter may be repeated if you want to append multiple arrays).
This function appends one or more data arrays to create a new combined array. Suppose you have created three data arrays like this:
local primaries,pastels,grays
primaries=dataarray("red","green","blue")
pastels=dataarray("pink","mauve","baby blue")
grays=dataarray("black","white")
You can use appenddataarrays( to combine all of these into a new data array.
local colors
colors = appenddataarays(primaries,pastels,grays)
The end result is an array with eight elements: red, green, blue, pink, mauve, baby blue, black and white.
Error Messages
appenddataarrays( function: Invalid appended data array. – All parameters to this function must be valid data arrays, created with dataarray(, importdataarray(, dataarraybuild(, etc.
