copypartialdictionary(
DICTIONARY
KEY
The copypartialdictionary( function partially copies a dictionary (see Data Dictionaries).
dictionary – is the name of the field or variable that contains the original dictionary (must contain binary data).
key – is the name of the key to copy. If you need to copy more than one key/value pair, more than one key parameter can be used.
The copypartialdictionary( function takes one or more key names and copies the associated key/value pairs from the original dictionary into a new one. For example, suppose you created a dictionary and stored it in variable named contact.
fileglobal contact,mailto
contact=initializedictionary("First","John","Last","Wilson",
"Address","3987 Olive","City","Tustin","State","CA","Zip","92841",
"Phone","562-309-5923","Email","jwilson@someisp.com")
Later, you could use the copypartialdictionary( function to create a second dictionary, called mailto, that contains just the address information (without the phone number, e-mail, or any other entries that may have been added to the original dictionary):
mailto=copypartialdictionary(contact,"Address","City","State","Zip")
Starting with Panorama X 10.2, the copypartialdictionary( function allows the second parameter to be a carriage return separated list of key names. When used this way, there must be only two parameters, not three or more. Here is an alternative version of the code above using this technique.
mailto=copypartialdictionary(contact,commatocr("Address,City,State,Zip"))
The advantage of this alternate method is that you can calculate the list of key names “on-the-fly.” This example creates a new dictionary with only items in the original dictionary that have names that begin with Shipping, for example ShippingAddress, ShippingCity, ShippingPhone, etc.
shipinfo=copypartialdictionary(contact,
arraystrip(arrayfilter(listdictionarykeys(contact),cr(),
{?(import() beginswith "Shipping",import(),"")}),cr())
- changedictionaryvalues( -- changes one or more values in a dictionary (see Data Dictionaries).
- classicdictionaryvalue( -- returns the value of an item in the dictionary, given its key (see Data Dictionaries). Unlike getdictionaryvalue(, this function does not treat keys as case sensitive.
- deletedictionaryvalue( -- deletes one or more key/value pairs from a dictionary (see Data Dictionaries).
- dictionaryassignmentscode( -- returns code that can be used to take the values in a dictionary (see Data Dictionaries) and assign them to fields or variables based on the dictionary keys.
- dictionaryfromarray( -- builds a new dictionary and initializes it from a two dimensional text array (see Data Dictionaries and Text Arrays).
- dictionaryfromvariables( -- builds a new dictionary and initializes it from a list of variables (carriage return delimited).
- dictionaryvalueexists( -- returns true or false depending on whether or not a key/value pair exists in a dictionary (see Data Dictionaries).
- dumpdictionary( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries).
- dumpdictionaryquoted( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries). The text values are quoted.
- dumpdictionarysource( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries). The keys and values are quoted so that they could be used to re-assemble the dictionary with the initializedictionary( function.
- getdictionarykey( -- returns the key of an item in the dictionary, given its value). This is essentially the opposite of the getdictionaryvalue( function (see Data Dictionaries).
- getdictionaryvalue( -- returns the value of an item in the dictionary, given its key (see Data Dictionaries).
- getglobaldictionary( -- converts a global dictionary into a regular dictionary.
- Global Dictionaries -- alertnate high performance method to store multiple data items, much faster than regular data dictionaries.
- globaldictionarykeys( -- returns a cr()-separated array containing the keys in a global dictionary, or the names of all global dictionaries.
- globaldictionaryvalue( -- returns the value of an item in a global dictionary, given its key (see Global Dictionaries).
- initializedictionary -- builds a new dictionary and initializes it with one or more key/value entries (see Data Dictionaries).
- initializedictionary( -- builds a new dictionary and initializes it with zero or more key/value entries (see Data Dictionaries).
- initializedictionaryvalue( -- builds a new dictionary and initializes it with one or more entries (see Data Dictionaries). This function is deprecated, we recommend using the initializedictionary( function instead.
- listdictionarykeys( -- returns a list of the keys in a dictionary collection.
- mergedictionaries( -- merges the contents of two or more dictionaries (see Data Dictionaries).
- renamedictionarykey( -- changes the key (name) of one or more values in a dictionary (see Data Dictionaries).
- timerinfo( -- returns a dictionary that contains all of the properties of a timer.
10.2 | Updated | If there are only two parameters, the second parameter is now a carriage return delimited list of keys to copy, making it easier to generate the list of keys with a calculation. |
10.0 | Updated | Carried over from Panorama 6.0, but now available as a function. Also, this operation no longer corrupts the dictionary if the same key is listed more than once. |
