dictionaryfromarray(
ARRAY
SUBSEPARATOR
SEPARATOR
The dictionaryfromarray( function builds a new dictionary and initializes it from a two dimensional text array (see Data Dictionaries and Text Arrays).
array – two dimensional text array containing the keys and values for the text array. The first column of the array contains the keys, the second column contains the values.
subseparator – the separator character (or characters) between the columns of the array. If this parameter is missing, the default subseparator is the tab character.
separator – the separator character (or characters) between the rows of the array. If this parameter is missing, the default separator is the carriage return character.
The dictionaryfromarray( function creates a new collection of values (dictionary) and initializes it with one or more key/value pairs from a two dimensional text array. This example creates a new dictionary collection containing a US mailing address.
initializedictionary("Address:3987 Olive,City:Tustin,State:CA,Zip:92841",":",",")
In this example the new dictionary will contain four values: Address, City, State and Zip.
This example takes the output from the sips shell command and converts it into a dictionary.
dictionaryfromarray(arrayfilter(after(lftocr(
shellscript("sips -g all "+imagefilepath)),cr()),cr(),
{strip(before(import(),": "))+"¬"+strip(after(import(),": "))}))
The output from the sips shell command is normally something like this:
/Users/jacksmith/Pictures/Flowers.png
pixelWidth: 1306
pixelHeight: 916
typeIdentifier: public.png
format: png
formatOptions: default
dpiWidth: 144.000
dpiHeight: 144.000
samplesPerPixel: 4
bitsPerSample: 8
hasAlpha: yes
space: RGB
profile: sRGB IEC61966-2.1
The formula above converts this into a Panorama dictionary. You can then easily extract items from this dictionary with the getdictionaryvalue( function. (Note: You wouldn’t actually need to use this example, because Panorama already includes an imageinfo( function that performs this for you.)
- changedictionaryvalues( -- changes one or more values in a dictionary (see Data Dictionaries).
- classicdictionaryvalue( -- returns the value of an item in the dictionary, given its key (see Data Dictionaries). Unlike getdictionaryvalue(, this function does not treat keys as case sensitive.
- copypartialdictionary( -- partially copies a dictionary (see Data Dictionaries).
- deletedictionaryvalue( -- deletes one or more key/value pairs from a dictionary (see Data Dictionaries).
- dictionaryassignmentscode( -- returns code that can be used to take the values in a dictionary (see Data Dictionaries) and assign them to fields or variables based on the dictionary keys.
- dictionaryfromvariables( -- builds a new dictionary and initializes it from a list of variables (carriage return delimited).
- dictionaryvalueexists( -- returns true or false depending on whether or not a key/value pair exists in a dictionary (see Data Dictionaries).
- dumpdictionary( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries).
- dumpdictionaryquoted( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries). The text values are quoted.
- dumpdictionarysource( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries). The keys and values are quoted so that they could be used to re-assemble the dictionary with the initializedictionary( function.
- getdictionarykey( -- returns the key of an item in the dictionary, given its value). This is essentially the opposite of the getdictionaryvalue( function (see Data Dictionaries).
- getdictionaryvalue( -- returns the value of an item in the dictionary, given its key (see Data Dictionaries).
- getglobaldictionary( -- converts a global dictionary into a regular dictionary.
- Global Dictionaries -- alertnate high performance method to store multiple data items, much faster than regular data dictionaries.
- globaldictionarykeys( -- returns a cr()-separated array containing the keys in a global dictionary, or the names of all global dictionaries.
- globaldictionaryvalue( -- returns the value of an item in a global dictionary, given its key (see Global Dictionaries).
- initializedictionary -- builds a new dictionary and initializes it with one or more key/value entries (see Data Dictionaries).
- initializedictionary( -- builds a new dictionary and initializes it with zero or more key/value entries (see Data Dictionaries).
- initializedictionaryvalue( -- builds a new dictionary and initializes it with one or more entries (see Data Dictionaries). This function is deprecated, we recommend using the initializedictionary( function instead.
- listdictionarykeys( -- returns a list of the keys in a dictionary collection.
- mergedictionaries( -- merges the contents of two or more dictionaries (see Data Dictionaries).
- renamedictionarykey( -- changes the key (name) of one or more values in a dictionary (see Data Dictionaries).
- timerinfo( -- returns a dictionary that contains all of the properties of a timer.
