arraydeletevalue(
ARRAY
VALUE
SEPARATOR
The arraydeletevalue( function deletes any array elements that match the value parameter. This must be an exact match, including upper and lower case. If the value occurs multiple times in the array, every occurence of the value will be removed, with one exception: if the value occurs in two consecutive array elements, only the first occurence will be deleted.
array – the original text array (see Text Arrays).
value – the value to remove from the array.
separator – the separator character or characters for this array.
This function deletes any elements in the array that match the value parameter. This must be an exact match, including upper and lower case. If the value occurs multiple times in the array, every occurence of the value will be removed, with one exception: if the value occurs in two consecutive array elements, only the first occurence will be deleted.
arraydeletevalue("a/b/c/d","d","/") ☞ a/b/c
arraydeletevalue("red,green,blue","blue",",") ☞ red,green
See Text Arrays for more information about arrays.
replace(thesep+thearray+thesep,thesep+thevalue+thesep,thesep)[length(thesep)+1,-(length(thesep)+1)]
10.0 | Updated | Carried over from Panorama 6.0 but more than one character is now allowed for use as the separator parameter. |
