mergedictionaries(
DICTIONARY1
DICTIONARY2
The mergedictionaries( function merges the contents of two or more dictionaries (see Data Dictionaries).
dictionary1 – is the name of the field or variable that contains the original dictionary (must contain binary data).
dictionary2 – is the name of the field or variable that contains the second dictionary (must contain binary data). You can repeat this parameter for three, four or more dictionaries.
The mergedictionaries( function takes two dictionaries and merges them into a new one. For example, suppose you created three dictionaries with information about a person named Mary Wilson.
fileglobal mailInfo,phoneInfo,emailInfo,contactInfo
mailInfo=initializedictionary("First","Mary","Last","Wilson",
"Address","3987 Olive","City","Tustin","State","CA","Zip","92841")
phoneInfo=initializedictionary("First","Mary","Last","Wilson","Phone","562-309-5923")
emailInfo=initializedictionary("First","Mary","Last","Wilson","Email","mwilson@someisp.com")
Later, you could use the mergedictionaries( function to create a combined dictionary that contains all of Ms. Wilson’s contact information:
contactInfo=mergedictionaries(mailInfo,phoneInfo,emailInfo)
If the the merged dictionaries contain one or more keys that are the same, the value in the dictionary farthest to the right will overide any dictionaries earlier in the list. In the previous example, all three of the dictionaries contained keys for First and Last, but they all contained the same values so there was no conflict. But what if there was a conflict, for example, suppose the e-mail dictionary contained a different last name (perhaps Mary got married).
emailInfo=initializedictionary("First","Mary","Last","Jackson","Email","mwilson@someisp.com")
If the three dictionaries are merged like this, the contactInfo variable will contain the last name Jackson.
However, if the order of the parameters is reversed, the final last name will be Wilson.
contactInfo=mergedictionaries(emailInfo,phoneInfo,mailInfo)
- changedictionaryvalues( -- changes one or more values in a dictionary (see Data Dictionaries).
- classicdictionaryvalue( -- returns the value of an item in the dictionary, given its key (see Data Dictionaries). Unlike getdictionaryvalue(, this function does not treat keys as case sensitive.
- copypartialdictionary( -- partially copies a dictionary (see Data Dictionaries).
- deletedictionaryvalue( -- deletes one or more key/value pairs from a dictionary (see Data Dictionaries).
- dictionaryassignmentscode( -- returns code that can be used to take the values in a dictionary (see Data Dictionaries) and assign them to fields or variables based on the dictionary keys.
- dictionaryfromarray( -- builds a new dictionary and initializes it from a two dimensional text array (see Data Dictionaries and Text Arrays).
- dictionaryfromvariables( -- builds a new dictionary and initializes it from a list of variables (carriage return delimited).
- dictionaryvalueexists( -- returns true or false depending on whether or not a key/value pair exists in a dictionary (see Data Dictionaries).
- dumpdictionary( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries).
- dumpdictionaryquoted( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries). The text values are quoted.
- dumpdictionarysource( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries). The keys and values are quoted so that they could be used to re-assemble the dictionary with the initializedictionary( function.
- getdictionarykey( -- returns the key of an item in the dictionary, given its value). This is essentially the opposite of the getdictionaryvalue( function (see Data Dictionaries).
- getdictionaryvalue( -- returns the value of an item in the dictionary, given its key (see Data Dictionaries).
- getglobaldictionary( -- converts a global dictionary into a regular dictionary.
- Global Dictionaries -- alertnate high performance method to store multiple data items, much faster than regular data dictionaries.
- globaldictionarykeys( -- returns a cr()-separated array containing the keys in a global dictionary, or the names of all global dictionaries.
- globaldictionaryvalue( -- returns the value of an item in a global dictionary, given its key (see Global Dictionaries).
- initializedictionary -- builds a new dictionary and initializes it with one or more key/value entries (see Data Dictionaries).
- initializedictionary( -- builds a new dictionary and initializes it with zero or more key/value entries (see Data Dictionaries).
- initializedictionaryvalue( -- builds a new dictionary and initializes it with one or more entries (see Data Dictionaries). This function is deprecated, we recommend using the initializedictionary( function instead.
- listdictionarykeys( -- returns a list of the keys in a dictionary collection.
- renamedictionarykey( -- changes the key (name) of one or more values in a dictionary (see Data Dictionaries).
- timerinfo( -- returns a dictionary that contains all of the properties of a timer.
10.0 | Updated | Carried over from Panorama 6.0, but now available as a function. Also, this operation now allows more than two dictionaries to be merged. |
