makenumberedarray(
SEP
START
END
The makenumberedarray( function generates a numeric sequenced text array.
sep – the separator character that will be placed between each number.
start – the starting number of the sequence (must be an integer).
end – the ending number of the sequence (must be an integer that is larger than the start value).
This function generates a numeric sequenced array.
makenumberedarray(",",1,3) ☞ 1,2,3
makenumberedarray(",",8,15) ☞ 8,9,10,11,12,13,14,15
| 10.0 | Updated | Carried over from Panorama 6.0, but much faster than before. |
