tabarray(
TEXT
ITEM
The tabarray( function extracts the nth element from a tab delimited array.
text – The item of text that contains the data you want to extract. This parameter can also be a binary value as long as the binary value contains text encoded using UTF-8.
item – The number of the data item you want to extract. The first item is 1, the second item is 2, the third is 3, etc. or you can use negative values, -1 (last item), -2 (second to last, etc.)
This function extracts the nth element from a tab delimited array.
tabarray("red"+tab()+"green"+tab()+"blue",2) ☞ green
See Text Arrays for more information about arrays.
array(thetext,theindex,tab())
| 10.0 | Updated | Carried over from Panorama 6.0, but now allows negative item numbers (which are relative to the end of the array). |
