arraycolumn(
ARRAY
COLNUM
ROWSEP
COLSEP
The arraycolumn( function extracts a column from a two dimensional array.
array – the original array
colnum – the column to extract – 1 for the first column, 2 for the second column, etc.
rowsep – the separator character or characters between rows in the array.
colsep – the separator character or characters between columns in the array.
This function extracts a column from a two dimensional array.
arraycolumn("red=1,green=2,blue=3,black=4",1,",","=") ☞ red,green,blue,black
arraycolumn("red=1,green=2,blue=3,black=4",2,",","=") ☞ 1,2,3,4
| 10.0 | Updated | Carried over from Panorama 6.0 but more than one character is now allowed for use as the rowsep and colsep parameters. |
