deletedictionaryvalue(
DICTIONARY
KEY
The deletedictionaryvalue( function deletes one or more key/value pairs from a dictionary (see Data Dictionaries).
dictionary – is the name of the field or variable that contains the dictionary (must contain binary data).
key – is the name of the key/value pair to delete. If you need to delete more than one key/value pair, more than one key parameter can be used. If there is only one, empty (""
) parameter, all key/value pairs will be removed.
The deletedictionaryvalue( function takes one or more key names and deletes the associated key/value pairs from the dictionary collection. For example, suppose you created a dictionary and stored it in a variable named mailto.
fileglobal mailto
mailto=initializedictionary("Address","3987 Olive","City","Tustin","State","CA","Zip","92841")
Later, you could use the deletedictionaryvalue( function to delete the Address and Zip values:
mailto=deletedictionaryvalue(mailto,"Address","Zip")
If you leave out the key name, all of the key/value pairs will be deleted:
mailto=deletedictionaryvalue(mailto,"")
However, there is an easier way to do this:
mailto=""
Advanced Note: ""
is the only text value that can be used as a dictionary – it represents an empty dictionary. Attempting to use a non-zero length text object as a dictionary will result in an error.
- changedictionaryvalues( -- changes one or more values in a dictionary (see Data Dictionaries).
- classicdictionaryvalue( -- returns the value of an item in the dictionary, given its key (see Data Dictionaries). Unlike getdictionaryvalue(, this function does not treat keys as case sensitive.
- copypartialdictionary( -- partially copies a dictionary (see Data Dictionaries).
- dictionaryassignmentscode( -- returns code that can be used to take the values in a dictionary (see Data Dictionaries) and assign them to fields or variables based on the dictionary keys.
- dictionaryfromarray( -- builds a new dictionary and initializes it from a two dimensional text array (see Data Dictionaries and Text Arrays).
- dictionaryfromvariables( -- builds a new dictionary and initializes it from a list of variables (carriage return delimited).
- dictionaryvalueexists( -- returns true or false depending on whether or not a key/value pair exists in a dictionary (see Data Dictionaries).
- dumpdictionary( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries).
- dumpdictionaryquoted( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries). The text values are quoted.
- dumpdictionarysource( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries). The keys and values are quoted so that they could be used to re-assemble the dictionary with the initializedictionary( function.
- getdictionarykey( -- returns the key of an item in the dictionary, given its value). This is essentially the opposite of the getdictionaryvalue( function (see Data Dictionaries).
- getdictionaryvalue( -- returns the value of an item in the dictionary, given its key (see Data Dictionaries).
- getglobaldictionary( -- converts a global dictionary into a regular dictionary.
- Global Dictionaries -- alertnate high performance method to store multiple data items, much faster than regular data dictionaries.
- globaldictionarykeys( -- returns a cr()-separated array containing the keys in a global dictionary, or the names of all global dictionaries.
- globaldictionaryvalue( -- returns the value of an item in a global dictionary, given its key (see Global Dictionaries).
- initializedictionary -- builds a new dictionary and initializes it with one or more key/value entries (see Data Dictionaries).
- initializedictionary( -- builds a new dictionary and initializes it with zero or more key/value entries (see Data Dictionaries).
- initializedictionaryvalue( -- builds a new dictionary and initializes it with one or more entries (see Data Dictionaries). This function is deprecated, we recommend using the initializedictionary( function instead.
- listdictionarykeys( -- returns a list of the keys in a dictionary collection.
- mergedictionaries( -- merges the contents of two or more dictionaries (see Data Dictionaries).
- renamedictionarykey( -- changes the key (name) of one or more values in a dictionary (see Data Dictionaries).
- timerinfo( -- returns a dictionary that contains all of the properties of a timer.
10.0 | Updated | Carried over from Panorama 6.0, but now available as a function. Also now allows multiple key/value pairs to be deleted by one function. |
