arraylast(
ARRAY
SEPARATOR
The arraylast( function extracts the last element of an array.
This function has two  parameters:
array – the original text array (see Text Arrays).
separator – the separator character for this array.
Extracts the last element of an array.
arraylast("red;green;blue;yellow;orange",";") ☞ orange
arraylast("north/south/east/west","/") ☞ west
See Text Arrays for more information about arrays.
array(thetext,arraysize(thetext,thesep),thesep)
or:
array(thetext,-1,thesep)
