arrayfirst(
ARRAY
SEPARATOR
The arrayfirst( function extracts the first element of a text array.
array – the original text array (see Text Arrays).
separator – the separator character or characters for this array.
This function extracts the first element of a text array.
arrayfirst("red;green;blue;yellow;orange",";") ☞ red
arrayfirst("north/south/east/west","/") ☞ north
See Text Arrays for more information about arrays.
array(thetext,1,thesep)
10.0 | Updated | Carried over from Panorama 6.0 but more than one character is now allowed for use as the separator parameter. |
