dumpdictionary(
DICTIONARY
The dumpdictionary( function returns a carriage return separated array of dictionary keys and values (see Data Dictionaries).
dictionary – is the name of the field or variable that contains the dictionary (must contain binary data).
This function returns a carriage return separated array of dictionary keys and values. Each line contains a key/value pair.
For example, this formula builds a dictionary and then dumps it.
dumpdictionary(initializedictionary("Color","Blue","Shape","Oval","Depth",3))
The result of this formula will be:
Color=Blue
Shape=Oval
Depth=3
Other functions that are related to this function are:
10.0UpdatedCarried over from Panorama 6.0, but uses new internal dictionary format
