randomarrayelement(
ARRAY
SEP
The randomarrayelement( function returns a random element from an array.
array – the text array.
sep – the separator character for the array.
This function returns a random element from an array. Each time you use this function a new random array element will be returned.
randomarrayelement("red green blue gold silver white black"," ") ☞ blue
randomarrayelement("red green blue gold silver white black"," ") ☞ silver
randomarrayelement("red green blue gold silver white black"," ") ☞ red
randomarrayelement("red green blue gold silver white black"," ") ☞ gold
10.0 | Updated | Carried over from Panorama 6.0, but is now much faster. |
