renamedictionarykey(
DICTIONARY
KEY
NEWKEY
The renamedictionarykey( function changes the key (name) of one or more values in a dictionary (see Data Dictionaries).
dictionary – is the name of the field or variable that contains the dictionary (must contain binary data).
key – name of an entry (this must be a text value). You can have more than one key parameter, as long as each key is accompanied by a new key name (see below).
newkey – is the new name of the entry.
The renamedictionarykey( function takes an existing collection of values (dictionary) and changes the name of one or more key/value pairs. This example creates a new dictionary collection containing a US mailing address and stores it in a variable named mailto.
fileglobal mailto
mailto=initializedictionary("Address","3987 Olive","City","Tustin","State","CA","Zip","92841")
Later you could use the renamedictionarykey( function to rename one or more of the values in the dictionary. (In this example the modified dictionary is being stored right back into the mailto variable, but it could be stored in a different field or variable.)
mailto=renamedictionarykey(mailto,"Address","Street","Zip","Postal Code")
You can see the changed values by using the dumpdictionaryquoted( function.
dumpdictionaryquoted(mailto)
Here is the result:
Street="3987 Olive"
City="Tustin"
State="CA"
Postal Code="92841"
Error Messages
renamedictionarykey( function is missing a value parameter. – This function requires an odd number of parameters. If an even number of parameters is supplied, this error will occur.
- changedictionaryvalues( -- changes one or more values in a dictionary (see Data Dictionaries).
- classicdictionaryvalue( -- returns the value of an item in the dictionary, given its key (see Data Dictionaries). Unlike getdictionaryvalue(, this function does not treat keys as case sensitive.
- copypartialdictionary( -- partially copies a dictionary (see Data Dictionaries).
- deletedictionaryvalue( -- deletes one or more key/value pairs from a dictionary (see Data Dictionaries).
- dictionaryassignmentscode( -- returns code that can be used to take the values in a dictionary (see Data Dictionaries) and assign them to fields or variables based on the dictionary keys.
- dictionaryfromarray( -- builds a new dictionary and initializes it from a two dimensional text array (see Data Dictionaries and Text Arrays).
- dictionaryfromvariables( -- builds a new dictionary and initializes it from a list of variables (carriage return delimited).
- dictionaryvalueexists( -- returns true or false depending on whether or not a key/value pair exists in a dictionary (see Data Dictionaries).
- dumpdictionary( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries).
- dumpdictionaryquoted( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries). The text values are quoted.
- dumpdictionarysource( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries). The keys and values are quoted so that they could be used to re-assemble the dictionary with the initializedictionary( function.
- getdictionarykey( -- returns the key of an item in the dictionary, given its value). This is essentially the opposite of the getdictionaryvalue( function (see Data Dictionaries).
- getdictionaryvalue( -- returns the value of an item in the dictionary, given its key (see Data Dictionaries).
- getglobaldictionary( -- converts a global dictionary into a regular dictionary.
- Global Dictionaries -- alertnate high performance method to store multiple data items, much faster than regular data dictionaries.
- globaldictionarykeys( -- returns a cr()-separated array containing the keys in a global dictionary, or the names of all global dictionaries.
- globaldictionaryvalue( -- returns the value of an item in a global dictionary, given its key (see Global Dictionaries).
- initializedictionary -- builds a new dictionary and initializes it with one or more key/value entries (see Data Dictionaries).
- initializedictionary( -- builds a new dictionary and initializes it with zero or more key/value entries (see Data Dictionaries).
- initializedictionaryvalue( -- builds a new dictionary and initializes it with one or more entries (see Data Dictionaries). This function is deprecated, we recommend using the initializedictionary( function instead.
- listdictionarykeys( -- returns a list of the keys in a dictionary collection.
- mergedictionaries( -- merges the contents of two or more dictionaries (see Data Dictionaries).
- timerinfo( -- returns a dictionary that contains all of the properties of a timer.
10.0 | Updated | Carried over from Panorama 6.0, but now allows more than one key/value pair to be renamed at a time. This operation is now available as a function that can be used a formula -- it was previously only available as the changedictionaryname statement (which still works for compatibility with older databases). |
