chararray(
TEXT
POSITION
The chararray( function extracts a single character from text.
text – the text containing the character to be extracted.
position – the position of the character, starting from 1. If a negative position is used, the position is calulated from the end of the text.
This function extracts a single character from text.
chararray("abcdef",4) ☞ d
chararray("abcdef",-2) ☞ e
(text)[position;1]
