arraynumerictotal(
ARRAY
SEP
The arraynumerictotal( function totals all the numeric elements of a text array.
array – The original numeric text array.
sep – The separator character or characters used in this array.
This function totals all the numeric elements of a text array.
arraynumerictotal("3+6+12","+") ☞ 21
arraynumerictotal("23,42,14",",") ☞ 79
10.0 | Updated | Carried over from Panorama 6.0 but more than one character is now allowed for use as the separator parameter |
