arrayboth(
ARRAYONE
ARRAYTWO
SEPARATOR
The arrayboth( function creates a new array from two arrays. The new array contains only items that are in both of the original arrays.
arrayone – the first array.
arraytwo – the second array.
separator – the separator character or characters. Both of the original arrays must use this separator, and the result will also use this separator.
This function creates an new array from two arrays. The new array contains only items that are in both of the original arrays. The output array will be sorted alphabetically. Empty array elements, if any, will not be included in the output array, even if both of the original arrays contain empty elements.
arrayboth("red,green,orange,blue,white","black,white,red,blue",",") ☞ blue,red,white
arrayboth("j.a.f.g.x","a.b.c.d.e.f.g.h.i",".") ☞ a.f.g
See Text Arrays for more information about arrays.
| 10.0 | Updated | Carried over from Panorama 6.0 but more than one character is now allowed for use as the separator parameter. |
