arrayreplacevalue(
ARRAY
OLDVALUE
NEWVALUE
SEPARATOR
The arrayreplacevalue( function changes array elements that match a specified value.
array – the original text array (see Text Arrays).
oldvalue – the value of the item (or items) that you want to replace. This must be an exact match, including upper and lower case.
newvalue – the new value of the item
separator – the separator character or characters for this array.
This function replaces any array elements that match the oldvalue parameter with the newvalue parameter. This must be an exact match, including upper and lower case. If the value occurs multiple times in the array, every occurence of the value will be replaced.
arrayreplacevalue("a/b/c/d","b","x","/") ☞ a/x/c/d
arrayreplacevalue("red,green,blue","green","gold",",") ☞ red,gold,blue
See Text Arrays for more information about arrays.
replace(thesep+thearray+thesep,thesep+oldvalue+thesep,thesep+newvalue+thesep)[2,-2]
| 10.2.2 | Updated | If the value to be replaced appears multiple times in the array, all occurences will be replaced. In previous versions, only the first occurence would be replaced. |
| 10.0 | Updated | Carried over from Panorama 6.0 but more than one character is now allowed for use as the separator parameter. |
