The globaldictionaryvalue( function returns the value of an item in a global dictionary, given its key (see Global Dictionaries).
This function has two parameters:dictionaryname – name of the global dictionary (must have been previously set up with the setglobaldictionaryvalues statement).
key – is the name of the key for the value you want to retrieve.
This function returns the value of an item in a global dictionary, given its key. For example, this formula returns the value associated with the Scale key in the MyValues global dictionary.
globaldictionaryvalue("MyValues","Scale") ☞ 80
See Global Dictionaries for an extended discussion of how this function can be used.
