arraylefttrim(
ARRAY
COUNT
SEPARATOR
The arraylefttrim( function removes one or more elements from the beginning of an array.
array – the original text array (see Text Arrays).
count – the number of items to remove from the beginning of the array.
separator – the separator character for this array.
This function removes one or more elements from the beginning of an array. For example arraylefttrim(text,2,",") removes the first two elements from a comma separated array.
arraylefttrim("red;green;blue;yellow;orange",1,";") ☞ green;blue;yellow;orange
arraylefttrim("red;green;blue;yellow;orange",2,";") ☞ blue;yellow;orange
arraylefttrim("red;green;blue;yellow;orange",3,";") ☞ yellow;orange
See Text Arrays for more information about arrays.
arrayrange(thetext,count+1,9999,sep)
