dictionaryassignmentscode(
DICTIONARY
The dictionaryassignmentscode( function returns code that can be used to take the values in a dictionary (see Data Dictionaries) and assign them to fields or variables based on the dictionary keys.
This function has one  parameter:
dictionary – is the name of the field or variable that contains the dictionary (must contain binary data).
This function returns code that can be used to take the values in a dictionary (see Data Dictionaries) and assign them to fields or variables based on the dictionary keys. The output of this function can be used directly in an execute statement as a series of assignments.
This function is part of a suite that manipulates items in a key/value dictionary. This is not a language dictionary for spelling checks, but a dictionary that allows you to define words (names) and their values (definitions).
For example, this formula builds a dictionary and then dumps it as code.
dictionaryassignmentscode(initializedictionary("Color Option","Blue","Shape","Oval","Total Depth",3))
The result of this formula will be:
«Color Option»="Blue"
Shape="Oval"
«Total Depth»=3
Other functions that are related to this function are:
- changedictionaryvalues( -- changes one or more values in a dictionary (see Data Dictionaries).
- classicdictionaryvalue( -- returns the value of an item in the dictionary, given its key (see Data Dictionaries). Unlike getdictionaryvalue(, this function does not treat keys as case sensitive.
- copypartialdictionary( -- partially copies a dictionary (see Data Dictionaries).
- deletedictionaryvalue( -- deletes one or more key/value pairs from a dictionary (see Data Dictionaries).
- dictionaryfromarray( -- builds a new dictionary and initializes it from a two dimensional text array (see Data Dictionaries and Text Arrays).
- dictionaryfromvariables( -- builds a new dictionary and initializes it from a list of variables (carriage return delimited).
- dictionaryvalueexists( -- returns true or false depending on whether or not a key/value pair exists in a dictionary (see Data Dictionaries).
- dumpdictionary( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries).
- dumpdictionaryquoted( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries). The text values are quoted.
- dumpdictionarysource( -- returns a carriage return separated array of dictionary keys and values (see Data Dictionaries). The keys and values are quoted so that they could be used to re-assemble the dictionary with the initializedictionary( function.
- getdictionarykey( -- returns the key of an item in the dictionary, given its value). This is essentially the opposite of the getdictionaryvalue( function (see Data Dictionaries).
- getdictionaryvalue( -- returns the value of an item in the dictionary, given its key (see Data Dictionaries).
- getglobaldictionary( -- converts a global dictionary into a regular dictionary.
- Global Dictionaries -- alertnate high performance method to store multiple data items, much faster than regular data dictionaries.
- globaldictionarykeys( -- returns a cr()-separated array containing the keys in a global dictionary, or the names of all global dictionaries.
- globaldictionaryvalue( -- returns the value of an item in a global dictionary, given its key (see Global Dictionaries).
- initializedictionary -- builds a new dictionary and initializes it with one or more key/value entries (see Data Dictionaries).
- initializedictionary( -- builds a new dictionary and initializes it with zero or more key/value entries (see Data Dictionaries).
- initializedictionaryvalue( -- builds a new dictionary and initializes it with one or more entries (see Data Dictionaries). This function is deprecated, we recommend using the initializedictionary( function instead.
- listdictionarykeys( -- returns a list of the keys in a dictionary collection.
- mergedictionaries( -- merges the contents of two or more dictionaries (see Data Dictionaries).
- renamedictionarykey( -- changes the key (name) of one or more values in a dictionary (see Data Dictionaries).
- timerinfo( -- returns a dictionary that contains all of the properties of a timer.
| 10.2 | Updated | New in this version. |
