webformitems(
The webformitems( function returns a list of POST parameters passed from a form to the web server, including both visible and invisible items (but excluding the special items Panorama generates for its own internal use).
This functions returns a list of POST parameters passed from a form to the web server, including both visible and invisible items (but excluding the special items Panorama generates for its own internal use). The list is formatted as a carriage return separated list. This example retrieves the names and then runs a loop to process each submitted item.
looparray webformitems(),cr(),formItem
// process each item submitted in form
let itemValue = webformitemvalue(formItem)
endloop
10.2 | No Change | Carried over from Panorama 6.0. |
