cgilinknewwindow(
DATABASE
SUFFIX
CAPTION
The cgilinknewwindow( function creates a domain independent link for another CGI action on the same server that opens a new browser window.
database – name of the database for the target URL. If “” then this is another procedure in the current database.
suffix – the rest of the URL, in other words, everything after the first ~.
caption – the caption for the URL. This is the text that the user will see on their web browser.
This function is designed to be used in a CGI routine to create a domain independent URL for another CGI action on the same server that opens a new browser window. In other words, the link will continue to work even if the server’s domain (or IP address) changes, or if the database is copied to a different server. The end result is a complete <a> tag that can be inserted into the HTML being generated by the current CGI procedure.
cgilinknewwindow("Catalog","Entry Form~Item=F7A","Edit Record")
    ☞ <a href="http://site.com/cgi-bin/Panorama.cgi?Catalog~Entry%20Form~Item=F7A" target="_blank">Edit Record</a>
