panoramaxservercgiurl(
SERVER
The panoramaxservercgiurl( function returns the URL associated with a Panorama X server cgi.
server – Name of the server you are interested in.
This function returns the URL associated with a Panorama X server, including the CGI.
panoramaxservercgiurl("ProVUE Server") ☞ http://provue.com/cgi-bin/panoramax.cgi
Note: This function only works with servers that have been configured in the Server Administration window.
- Web Cookies -- web cookies.
