servervariable(
DATABASE
VARIABLE
The servervariable( function returns the value of a server variable (a permanent variable on the server).
database – name of the shared database that contains the server variable. If this parameter is missing or empty, the current database is assumed.
variable – name of the shared variable to be accessed. The name must either be quoted, or calculated by a formula.
This function returns the value of a server variable (a permanent variable on the server). Depending on your network speed and how busy the server is, there may be a slight delay before this function returns the requested data (however there is no delay if this function is run on the server in web code).
- Web Cookies -- web cookies.
10.2 | Updated | Carried over from Panorama 6.0, but now the database parameter is optional. |
