weblink(
URL
CAPTION
The weblink( function builds an HTML link tag
url – the url for the link (for example http://www.apple.com).
caption – the caption for the link (for example Apple). If the caption is not supplied ("") the URL will be used for the caption.
This function builds an HTML link tag.
weblink("http://www.provue.com","ProVUE") ☞ <a href="http://www.provue.com">ProVUE</a>
weblink("http://123.45.67.89","") ☞ <a href="http://123.45.67.89">http://123.45.67.89</a>
Note: If this function is embedded in a formula in a form the form will only display the caption, not the url. When the form is rendered on a server, however, the full URL will be generated.
