webformlinknewwindow(
DATABASE
FORM
RECORD
CAPTION
The webformlinknewwindow( function generates a link to a Panorama form on the current web site.
database – database to link to (must be on same web server).
form – form to link to (this form must have been previously rendered to HTML and uploaded to the web server).
record – identifies which record should be used to populate the form, leave this blank for a blank form. Otherwise, see the weburlselect statement.
caption – the caption that will be displayed for this link. If left blank, the form name will be used as the caption.
This function generates a link to a Panorama form on the current web site in a new browser window.
webformlinknewwindow("MailingList","Advanced Search","","Search")
☞ <a href="http://site.com/cgi-bin/Panorama.cgi?MailingList~Form~Advanced%20Search">Search</a>
- cgilink( -- creates a domain independent URL for another CGI action on the same server.
- cgilinknewwindow( -- creates a domain independent link for another CGI action on the same server that opens a new browser window.
- cginavlink( -- creates a domain-independent navigation link for the current record in this database.
- cginavlinknewwindow( -- creates a domain-independent navigation link (to a new browser window) for the current record in this database.
- htmldecode( -- converts HTML text into regular text by converting any special HTML entities (`&`, `©`, etc.) into the corresponding characters.
- htmlencode( -- converts standard text into HTML text by converting any special characters into the equivalent HTML entities.
- webformlink( -- generates a link to a Panorama form on the current web site (the link will open in a new browser window).
- weblink( -- builds an HTML link tag
- weblinknewwindow( -- builds an HTML link tag
