dbserverdomain(
The dbserverdomain( function returns the server domain for the database.
This function returns the domain of the server the code is running on (this function only works when running on a web server).
This example takes a variable named imageurl and checks if it contains a domain name. If it doesn’t, the domain name of the current server is added.
if imageurl beginswith "/"
    imageurl = dbserverdomain()+imageurl
Suppose your server domain is http://www.mysite.com, and you set imageurl to /images/face.jpg. After you run the code above imageurl will be changed to:
http://www.mysite.com/images/face.jpg
10.2No ChangeCarried over from Panorama 6.0.
