listwebtemplates(
DATABASE
The listwebtemplates( function retrieves a list of web templates in the specified database, if any.
This function has one  parameter:
database – name of the database to search, or “” for the current database. The specified database must be open.
This function retrieves a list of web templates in the specified database, if any. This example displays a list of templates in the current database.
let templateList = listwebtemplates("")
message templateList
| 10.2 | Updated | Carried over from Panorama 6.0, but now stores the template in the form itself, and allows a database to be specified. |
