cginavlinknewwindow(
PROCEDURE
CAPTION
The cginavlinknewwindow( function creates a domain-independent navigation link (to a new browser window) for the current record in this database.
procedure – the procedure being linked to. This must be a procedure in the current database.
caption – caption for the URL. This is the text that the user will see on their web browser.
This function is designed to be used in a CGI routine to create a domain-independent navigation link (to a new browser window) for the current record in this database. The end result is a complete <a>
tag that can be inserted into the HTML being generated by the current CGI procedure.
cginavlinknewwindow("edit","Edit Record")
☞ <a href="http://site.com//cgi-bin/Panorama.cgi?Catalog~edit~=
4996" target="_blank">Edit Record</a>
In this result, 4996
is the id number for the current record.
- cgilink( -- creates a domain independent URL for another CGI action on the same server.
- cgilinknewwindow( -- creates a domain independent link for another CGI action on the same server that opens a new browser window.
- cginavlink( -- creates a domain-independent navigation link for the current record in this database.
- htmldecode( -- converts HTML text into regular text by converting any special HTML entities (`&`, `©`, etc.) into the corresponding characters.
- htmlencode( -- converts standard text into HTML text by converting any special characters into the equivalent HTML entities.
- webformlink( -- generates a link to a Panorama form on the current web site (the link will open in a new browser window).
- webformlinknewwindow( -- generates a link to a Panorama form on the current web site.
- weblink( -- builds an HTML link tag
- weblinknewwindow( -- builds an HTML link tag
10.0 | Updated | Carried over from Panorama 6.0, but now works with non-shared databases (of course, the database must still be on a server). |
