aliaspath(
PATH
The aliaspath( function returns the path an alias points to (or an error if the specified file isn’t an alias).
path – is a path to an alias file, including the file (or folder) name (see Files and Folders for more information about file paths).
This function returns the path an alias points to (or an error if the specified file isn’t an alias).
aliaspath("~/Documents/myaliasfile") ☞ /users/bob/Documents/some file.txt"
