pathcontains(
PATH
FILE
The pathcontains( function checks to see if a folder contains a specified file (or folder).
path – path to the folder to be checked.
file – name of file or folder.
This function checks to see if a folder contains a specified file (or folder).
pathcontains("~/Dropbox","Photos") ☞ -1 (true)
pathcontains("~/Dropbox","Maps") ☞ 0 (false)
arraycontains(foldercontents(path),thefile,¶)
