unixshellpath(
PATH
The unixshellpath( function converts a path and filename into a POSIX path that can be embedded within the shellscript statement.
path – path and filename to be converted. Can be either a standard UNIX path or an HFS path. If an HFS path is passed, it must be a full path, including the disk name - relative HFS paths are not allowed.
This function converts a path and filename into a POSIX path that can be embedded within the shellscript statement. Special characters are not escaped with the backslash (\) character, if you need these characters to be escaped use the posixpath( function.
unixshellpath("~/Dropbox/Miscellaneous/*Important* Anthem Staff Change.pdf")
☞ /Users/tomswift/Dropbox/Miscellaneous/*Important* Anthem Staff Change.pdf
unixshellpath("External HD:Users:Shared:SheepShaver:Mac OS ROM")
☞ /Volumes/External HD/Users/Shared/SheepShaver/Mac OS ROM
unixpath(thepath)
- applescriptconstant( -- converts an expression into an AppleScript literal.
- javascriptconstant( -- converts an expression into a JavaScript literal.
- javascriptstring( -- converts a text string into a JavaScript string
- perlconstant( -- encodes text for use as a constant in a Perl program.
- phpconstant( -- encodes text for use as a contant in a php program.
- pythonconstant( -- encodes text for use as a constant in a python program.
- rubyconstant( -- encodes a value for use as a constant in a Ruby program.
- runningappinfo( -- returns information about applications that are currently running on this computer.
- Scripting Panorama X with AppleScript -- embedding Panorama code into AppleScript (allowing Panorama to be controlled from other programs).
- unixshellstring( -- encodes text for use as a parameter to a unix shell command.
