filedate(
PATH
The filedate( function returns the modification date of a file.
path – is a path to the file, including the file name (see Files and Folders for more information about file paths).
This function returns the modification date of the specified file.
This example checks to see if the news.txt file is more than 30 days old, and if so, deletes it.
if filedate("~/Documents/news.txt") < today() - 30
fileerase "~/Documents/news.txt"
Tip: If you want to display the date, use the datepattern( function.
Legacy Syntax (Separate Folder and File Parameters)
In older versions of Panorama (6.0 and earlier) the filedate( function had two parameters, folderid and filename. To maintain compatibility with older databases, two parameters will still work, as shown in this example:
filedate(folder("~/Documentation"),"news.txt")
For new databases you’ll probably find it easier to use the single parameter mode.
10.0 | Updated | Carried over from Panorama 6.0, but now may have either one parameter (path) or two (folder, path). |
