fileexists(
PATH
The fileexists( function returns true if a file exists, false if it does not.
path – is a path to the file, including the file name (see Files and Folders for more information about file paths).
This function checks to see if a file exists.
if fileexists("~/Documents/news.txt") = false()
    message "No news available!"
Legacy Syntax (Separate Folder and File Parameters)
In older versions of Panorama (6.0 and earlier) the fileexists( had two parameters, folderid and filename. To maintain compatibility with older databases, two parameters will still work, as shown in this example:
fileexists(folder("~/Documentation"),"news.txt")
For new databases you’ll probably find it easier to use the single parameter mode.
10.0UpdatedCarried over from Panorama 6.0, but now may have either one parameter (path) or two (folder, path).
