fullpath(
PATH
The fullpath( function converts a filename or relative path (starting with the : or / symbol) into a full HFS path, including the disk name.
path – filename or relative path.
This function converts a filename or relative path (starting with the : or / symbol) into a full HFS path, including the disk name (see Files and Folders to learn more about HFS).
fullpath("myphoto.jpg") ☞ Macintosh HD:Users:tomswift:Databases:myphoto.jpg
?(thepath contains info("foldersepchar"),?(thepath beginswith info("foldersepchar"),dbpath()+thepath[2,-1],thepath),dbpath()+thepath)
