The archivecontents( function lists the contents of a compressed archive in .zip, .tar.gz or .tar.bz2 format.
This function has one parameter:archivefile – the path and filename of an archive file (the path may be absolute or database-relative).
This function lists the contents of a compressed archive in .zip, .tar.gz or .tar.bz2 format. If an archive contains multiple files, each will be listed on a separate line.
archivecontents("~/Documents/Snapshot.zip") ☞ Flower.tiff
