homesubfolder(
SUBPATH
The homesubfolder( function returns the folder id of a subfolder of the current user’s home folder.
subpath – the desired subfolder. This could be two or more levels deep, in which case each folder name should be separated by / (for compatibility with older versions of Panorama, a colon (:) is also accepted).
This function returns the folder ID of a subfolder of the current user’s home folder.
homesubfolder("Documents") ☞ /Users/johnsmith/Documents
homesubfolder("Library/Application Support") ☞ /Users/johnsmith/Library/Application Support
