fileexistspath(
PATH
The fileexistspath( function tests to see if a file exists.
path – path and filename of file.
This function tests to see if a file exists.
fileexistspath("~/Desktop/Installer Log.txt") ☞ -1 (true)
Note: This function is no longer necessary since the fileexists( function now allows the use of a single combined path/filename parameter.
fileexists(thepath)
10.0UpdatedCarried over from Panorama 6.0, but this function is no longer necessary since the fileexists( function now allows the use of a single combined path/filename parameter.
