foldercontains(
PATH
FILE
The foldercontains( function checks to see if a folder contains a specified file. See also the pathcontains( function.
path – path to the folder to be checked.
file – name of file or folder.
This function checks to see if a folder contains a specified file. See also the pathcontains( function.
foldercontains("~/Dropbox","Photos") ☞ -1 (true)
foldercontains("~/Dropbox","Maps") ☞ 0 (false)
arraycontains(listfiles(thefolder,""),thefile,¶)
