subfolder(
FOLDER
SUBFOLDER
The subfolder( function returns the folder id of a subfolder of a specified folder
folder – the original folder
subfolder – the desired subfolder. This could be two or more levels deep, in which case each folder name should be separated by / (for compatibility with older versions of Panorama, a colon (:) is also accepted).
This function returns the folder ID of a subfolder of a specified folder.
subfolder(info("userfolder"),"documents") ☞ /Users/johnsmith/documents
You can specify a subfolder of a subfolder (for as many levels deep as you need).
subfolder(info("userfolder"),"dropbox/personal") ☞ /Users/johnsmith/dropbox/personal
For compatibility with older versions of Panorama, a colon (:) is also accepted as the subfolder separator.
subfolder(info("userfolder"),"dropbox:personal") ☞ /Users/johnsmith/dropbox/personal
folder(folderpath(thefolder)+replace(subfolder,":",info("foldersepchar")))
