pathexists(
FILEPATH
The pathexists( function checks to see if a path exists.
filepath – a path to a folder. This may be either a UNIX path or an HFS path. (See Files and Folders for more information.)
Checks to see if a path to a folder exists. Returns true or false.
pathexists("/Users/tomswift/Dropbox") ☞ -1
pathexists("/Users/tomswift/NoDropbox") ☞ 0
Note: This function is identical to the folderexists( function.
folderexists(thepath)
